NEW TFS heads - sensor holes too big, common?
Old Apr 16, 2006 | 05:32 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I've got a new pair of TFS heads just installed and the holes tapped/threaded on each cyl head for the fan switch and the temp sensor I think? are just slightly bigger than needed.
Anyone experienced this before?
Just curious if it's common and what method used to get those suckers in.
Thanks!
Old Apr 16, 2006 | 05:38 PM
The sensor holes are the correct size.
For applications before about 76.
Somewhere around there, they changed them from ½" pipe, to 3/8" pipe.
Go to the hardware store and get a brass bushing from the plumbing section.
Also, the temp gauge sender for an earlier-model application, will work fine; something like, say, a 69 Chevelle 350. I can't think of anything that had a fan switch that size though.
Old Apr 16, 2006 | 05:45 PM
Car: '89 GTA
Well that's interesting and odd.
You would think if they advertise the heads for 87-95, etc. they would have the correct size holes.
So 2 brass bushings and I'm all set huh?
Thanks for the info.
evilstuie
Jan 9, 2020 08:29 PM
bamaboy0323
Sep 3, 2015 06:07 AM
89mulletbird
Aug 12, 2015 07:08 PM
