Charcoal canister removal
Old Apr 16, 2006 | 09:39 PM
Abubaca's Avatar
Block off the vent line to the tank and run a vented gas cap? Is it that simple? There's SO much info and debate, and the search offers up WAY too much to read.
....just looking for opinons here......
Old Apr 16, 2006 | 09:57 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I was thinking about removing mine last year, but the general concensus at that time was to just leave it...but some people did say you could just use a vented gas cap....although the gasoline "system" and tubing isn't something i really wanted to play with...i thought I'd just leave well enough alone in that area.
Old Apr 16, 2006 | 10:03 PM
Abubaca's Avatar
I tend to agree. As much as I don't like it, I DO like leaving well enough alone sometimes.
I've done a pretty good job of rerouting vaccum lines anyway. It's not too bad now.
Old Apr 16, 2006 | 10:22 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I also did some extensive reasearch on the above mentioned post, I came up with many negative and some positive responses, so I decided to leave my cannister and re-route the carb hose.
Old Apr 16, 2006 | 10:33 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
I took mine out. freed up lots of space. The canister had gotten pretty dirty too. like filthy this thing was sick so it couldnt been have doing much good anyway.
Old Apr 17, 2006 | 12:04 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I put a cheapo import fuel filter on the line, instead of capping it, right at the rear left shock area. then left the cap alone.
Old Apr 17, 2006 | 12:24 AM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
If you have TPI, no harm will come from removing it except a mild decrease in fuel economy. This coming from experience.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
TBRays98
Sep 6, 2015 05:05 PM
