1.6 rr's change springs??
Old Apr 25, 2006 | 04:01 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Hey all i've got a zz4 350 crate motor and would like to throw in a set of 1.6 RR's but i was told i would have to also change the springs anyone know what kind of springs i would need?
thanks
Old Apr 25, 2006 | 10:03 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
If youre referring to 1.6 rocker arms, you should be fine, as long as you dont have a big cam in there. You shouldn't need to change anything. I would do some reasearch on the total lift capacity of your heads and your cam size. Do the math before you do anything to make sure you can take it (divide total cam lift by 1.5 then multiply by 1.6. Check this figure against the bind height of your springs). If you do have to change springs, its not hard, just pretty annoying while the heads are on the engine.
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Dialed_In
Aug 20, 2015 01:45 PM
