Choking!
Old Apr 27, 2006 | 07:17 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
Choking!
I just had the most awesome driving experience of my life.
I noticed on the way to work that the car seemed like it was choking a bit, it had been doing this since i got it back, but was much more pronounced now. Kinda like the pressure was jumping around.
Well as I was driving down the highway after work and the car started jumping REAL bad and the tachometer was all over the place, if i gave it any gas, the thing would choke more. It was so bad that i was barely moving. So i pulled over and ripped open the dash on the drivers and passenger sides and checked all the wiring to make sure nothing was loose or grounding out or whatever. that checked out, so i popped the hood and checked for the same things. still nothing.
Started her back up and still the tach jumped like crazy, and when i gave it some gas, it just jumped forward and made bad noises.
Im not sure how else to describe how awesome.com this experience was.
Steve (89vert) had a pressure gauge hooked up the car and noticed that the regulator wasnt showing steady.
So far, thats all i have to go on.
Old Apr 27, 2006 | 07:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like one or more cylinders not firing.
Old Apr 27, 2006 | 08:11 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
the car barely drives it just jumps forward
Old Apr 27, 2006 | 10:08 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
MAF? or is it Speed density?
Old Apr 27, 2006 | 10:14 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
speed density
Old Apr 29, 2006 | 08:15 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
http://www.turbosport.ca/images/othe...obrokey002.MOV
short movie of what it is doing
Old Apr 29, 2006 | 09:59 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
While looking around, i discovered this:
http://www.turbosport.ca/images/othe...obrokey003.jpg
http://www.turbosport.ca/images/othe...obrokey004.jpg
Im assuming it was plugged into the manifold and is some sensor because i found the part of it thats still in the manifold.
I dont know what it is, and doubt its related to this problem, but who knows...
Old Apr 30, 2006 | 09:55 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
ttt
Old May 2, 2006 | 11:26 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
anybody?
Old May 3, 2006 | 11:02 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I can't see the first pic clearly. I'm guessing O2 sensor or temp sensor, depending on where's it was plugged into something. You said manifold, as in exhaust manifold?
purple wire is 02 sensor, would be plugged into exhaust manifold (well, into the O2 sensor.)
temp sensor is plugged into drivers side head usually. Those are the only wires I can think of that are plugged into the motors sides...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
