Making an A/C system...
Old Apr 29, 2006 | 12:46 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
I took the A/C system out of my car some time ago now.
What components would i be looking at to add a very simplistic a/C system?
-a/c compressor
-lines
-accumulator
-condensor
-dryer
I think i have that all down, but to the complicated part, i still have the "hot/cold" lever in the car for a/c and the a/c heater box and all.
I cut that wiring harness out with the ECM harness, so the liklyness of me being able to assemble it again, are slim to none. No biggie, i can wire up a flit switch for a/c to engage the compressor right?
what would be complications with this, and has anyone done it?
thanks
Old Apr 30, 2006 | 03:27 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
bump.....
Old Apr 30, 2006 | 03:52 PM
The wiring is the easiest part of the whole deal.
The A/C harness is its own completely separate harness assembly, it shares no wires whatsoever with any other harness. It even comes with the little vacuum lines you need, to feed vacuum into the passenger compartment to work all the little doors, and to carry the vacuum "supply" to the heater control valve, if the car has one. The harness goes through the firewall in its own little rubber grommet, separate from everything else.
It's a no-brainer. Just go to the buzzard and gank one out of another car, and be done with it. No sense in beating your brains out trying to re-invent the wheel when it's so easy to just do it right.
Old Apr 30, 2006 | 07:05 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
which side of the bay do the HVAC wires come into it?
Old Apr 30, 2006 | 07:12 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I don't want to be picky, but you have the electric fan system to deal with when doing A/C. The cooling fan turns on when the A/C is used.
Old Apr 30, 2006 | 07:24 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
very easy to do as well. the wires that go to actuate the compressor, also activate the relays that turns the fan on...
Old May 1, 2006 | 06:21 AM
The rear. Through the firewall. Right below the heater hose nipples.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
dm3k
Brakes
Aug 29, 2015 01:53 PM
BikeFarm
Aug 11, 2015 11:35 PM
