Engines knocking need advice
Old May 2, 2006 | 07:02 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Need some advice seems like I am going to need an engine.
I dont want to rebuild this one. Just did a T-5 swap also.
I also have another rear 342 open thats in good shape in my yard.
I wanted to keep this camaro since its a hard top and chassis
isnt rotted away.
I was looking at the reman 305 80-85 on ebay I know its not alot of
power but I just need to get to work with decent gas milage
for now..
Old May 2, 2006 | 09:30 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
why not wander down to GM and grab one of their el-cheapo low HP crate motors if you dont want big HP?
their nothing special but at least you got a 36month/100,000mile warranty!
Old May 2, 2006 | 09:39 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
wander down to GM
el-cheapo
I don't think cheap and GM ever belong in the same sentence.... Where else can you pay a 16 yr old punk $112/hr to screw up an oil change? Or a carpet install? Or pay $12 for a nut? Or wait a week to get in an idler pulley, pay $106 for it, and it's not even a genuine AC-Delco GM part, it's a $12 dayco that the local parts stores refused to bring in for me.... err, ahem...
the low power needs for now isn't a good reason to get another 305, it'd be very close to the same price to get a 350, then you can always get more power later with upgrades. (more power then you would with the same upgrades on the 305).
Old May 2, 2006 | 09:56 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
cheap and GM can belong in the same sentence. so long as it doesnt have anything to do with the shop...
IMO when you can go to GM, BS the parts guy for a bit and walk out with one of them gutless crate motors for under $1500ca that have a 3 year warranty its not that bad of a deal!
Old May 2, 2006 | 10:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
well i've been price raped by service and parts, so I can't really agree with you.
However, if I would have known I could have gotten a brand spankin' new 350 (albeit low perf), for $1500CA, I woulda jumped on that like a fat kid on a smartie.
Old May 2, 2006 | 11:50 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Maybe Ill will go to a few local rebuilders
and get the engine checked out see what they say first.
Before I do anything.
Old May 2, 2006 | 11:58 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Living in a large city like calgary they would be less likely to budge on the pricing like they will do in small places like up here. They just figure well hey, if he doesnt want to pay full price theirs lots more that can/will. Up here they will take what they can get, if that means only making a few bucks profit on stuff to them its worth it.
Old May 2, 2006 | 11:59 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
you know what . I just had a engine rebuilt . It gets better milage than my old 305 did . If you can get into tuneing , you can make them fairly good on gas IMO ( I drive two V-8's now )
Old May 2, 2006 | 02:36 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
If it's knocking, why not locate the bad part, replace it and call it a day. Save your money for your next motor.
Old May 2, 2006 | 03:42 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I cant do it no place to work I did the rearend and t5 in the street.
I dont want to keep driving it like this its very annoying.
I put around 2k miles on it like this..didnt get worse kinda wierd..but
Im sure its the motor now since after I took out the tranny it still made
that same sound at idle but goes away and comes back and gets stronger
when driving..
Old May 2, 2006 | 04:44 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I had a spun main bearing that sounded similar to what youre describing. If that is the case, you cant just fix it in the car...the block would need to be line bored and a new crank would be needed more than likely. If youre lucky you can keep driving it until you figure out what youre going to do, but it could go at any time.
Old May 8, 2006 | 03:17 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I took it today to the local speed shop the guys who are into
muscle and drag racing, he was nice enough to go for a ride with me.
He also checked it out from the engine bay before we left..
He said no way its an engine knock but he couldnt tell me what it was..
I told em I just did the 5 speed swap and when I had the tranny out
it still made that noise, he didnt know what it was either..
He said I could try to retard the timing perhaps the indicator is off
and im way to advanced..he also mentioned the exhaust well I checked
that, maybe my motor mounts? I dont know they did look dry and cracked a bit but the engine didnt move when it made that sound at around 2000rpms
sitting at the curb..
I asked him a couple of more questions like maybe the cam? or some
other stuff just thrown out there fuel pump distributor..
he did mention that its an older engine so I shouldnt expect it to run like glass.
Well after I thanked him for his time we shook hands and I left happy that it
wasnt a major problem but then again its still a mystery after all this time..
which buggs me ...I did get confident and did a burn out in 1st gear : )
Old May 8, 2006 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How many times do you have to be told you're going to the wrong dealership?
Old May 8, 2006 | 07:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
ha, if I can get to a decent one during business hours i'd be ok. What do you pay for an idler pulley for your DOHC motor? Think a stealerships will sell me a panhard rod nut for under $12? I don't actually *need* to buy much at a dealership, so the few things I do, I just suck it up and pay the big bills. Otherwise I avoid it like the plague.
Old May 8, 2006 | 07:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's always Saturday.
The places I dealt with would tell me when an aftermarket part was cheaper, then they'd phone NAPA or PartSource or whoever and have the part delivered over for me while I sat at the counter and drank coffee and BS'ed waiting for it to arrive.
Old May 8, 2006 | 07:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
What color is the sky in your world apeiron?
PS. And the dealership name. That's important.
Old May 9, 2006 | 08:57 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
could one of your rocker arm nuts loosened up on you?
Old May 9, 2006 | 09:38 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I dont know I guess I could check it out. thanks
Just wierd the sound comes up from the back of the engine.
threw the trans tunnel..
Old May 9, 2006 | 02:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
back of the engine? have you checked the starter and flywheel bits? something could have broken off, and is flopping around. Probably not a huge hassle to pull your trans and check it out...
Old May 9, 2006 | 10:19 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
It made the sound with the flexplate on and the auto tranny out
also made it with the flywheel on when I swapped it for the t5..
Guess to further investigate I have to get it up on the ramps again
and have someone it the throttle until it comes..Ive dont it before
awhile ago and couldnt figure it out..
Its inexplicable to say the least..
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
