Alernator Specifications
Old May 2, 2006 | 02:34 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
My father and I are looking for a rebuilt alternator and found a few at a local yard. But, I'm at college, about an hour and a half away from my father, and he needs to know the specs. on my current alternator because the guy at the yard said there are different alternators for different camaros and we'll need to match it up as closely as possible. So, I was wondering if all alternators were the same for a 1987 Camaro RS 305 and if anyone knew the specifications necessary to pick up a new one.
Old May 2, 2006 | 03:15 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
1987 is the only year that all alternators are the same 5.0 carb, or tpi. It is a one year only alternator. It should be 105amp. I work at NAPA and I just looked it up.
Old May 2, 2006 | 03:20 PM
hihighost's Avatar
Car: 1987 Camaro
Thank you very much.
Old May 2, 2006 | 04:15 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
its not that complicated though
its either a large housing or a small housing one
and you can swap whatever pulley you need, v belt or serpentine
its simple
good luck
MY87LT
Car Audio
38
Dec 2, 2020 01:44 AM
rrwebster
Mar 21, 2010 02:29 PM
NW94Z
Jul 9, 2008 01:40 PM
British Rich
Jun 3, 2008 04:29 AM
