slightly O/T 305 to 350
Old May 2, 2006 | 04:26 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
i have a aluminum intake with a rochester 2bbl carb,thought to be from a 78-79 camaro 305,on my '70 350 my Qjet has major problems,can i just swap the intakes and carbs??the 2bbl may be a little better on gas also,don't really need a big 4bbl on the truck anyway
Old May 2, 2006 | 04:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yea you can drop it on there without a problem. so long as its SB-SB not something off a BB...
Old May 2, 2006 | 04:56 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
definitely small block
changed valve covers from the chrome ones that came on it to some stockers off the same 305 that the intake came off,the older 350 isn't charcoal canistered or any smog stuff period,but the 305 intake has vac ports and EGR provisions and something i've not seen b4,it's a tube that curls down into the intake galley and comes back thru the manifold as a long tube,must be some sort of vacuum port or something,i don't remember having anything hooked to it in the past?but it's been off a running motor for years
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
