Car running rich and stalling?
Old May 5, 2006 | 09:40 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I've got a 87 tpi and I can't seem to figure out why it's acting this way.
The idle is jumpy, it goes from 1000 rpm to 500 at will. Sometimes when coming to a stop it'll be around 2000. I changed the ICM, and it's better but still all over... and to top it off it smells really gassy. I searched, but I didn't find much, has anyone got any suggestions?
Old May 5, 2006 | 12:15 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
openning suggestion would be to check your fuel pressure and post back on the board.
Old May 5, 2006 | 12:58 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
CTS sensor can do this . Also the surgeing part could be a fauly MAF burnoff relay .
Old May 5, 2006 | 01:28 PM
soultron's Avatar
Car: 87 trans am
I hadn't thought of that, my temp light does come on when I start the car I thought the meter was dead... Where migh the CTS be? My haynes manual isn't great.
Old May 5, 2006 | 01:51 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
on the front of the intake manifold...under the throttle body and such...
Old May 5, 2006 | 02:02 PM
soultron's Avatar
Car: 87 trans am
While I'm at it, I can't seem to get any codes except 12 even though my car is running rough. That seems odd, but I'm off to check the sensor.
Old May 6, 2006 | 08:54 PM
soultron's Avatar
Car: 87 trans am
Well, I disconected the battery and the check engine light finally came on. I got my code reader out and got a 15. Temp sensor it is.
Thanks for the tips guys!
Old May 20, 2006 | 07:08 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
cts = coolant temperature sensor?
Old May 20, 2006 | 11:28 PM
soultron's Avatar
Car: 87 trans am
yeah, but I'm stll having other problems, I'm changing the Fuel pump and I noticed the fuel pump relay wiring looks like five year olds patched in up. oh boy.
MustangBeater20
Oct 29, 2022 09:20 PM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
Kaweh
Aug 9, 2015 02:54 PM
