Battery hold-down bolt
Old May 11, 2006 | 12:37 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Anyone know the size of the battery hold-down bolt? I think it is either 5/16"-18 or M8. Length? Maybe 2" or 2.25" or 2.5"?
This is an '86 V6.
Old May 13, 2006 | 08:27 AM
Vader's Avatar
M8-1.25 x 60, hex head SEMS, all thread with a pilot point. The OEM came with zinc phosphate coating, but a standard zinc or cadmium plated fastener would probably work fine, and no one would know the difference.
Old May 13, 2006 | 02:26 PM
Wow! That's a lot of information. Thanks. I was actually able to uncover the marking on the top with a hard-bristled brush. But I sheared the head of the bolt off trying to take it out and for 4 days I've been trying to get the other half out with no success and regardless of how much penetrating lubricant I use.
Old May 14, 2006 | 12:26 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Two words
MAP Gas. Heat tends to get those frozen bolts real nice like. Must have been a lot of corrosion on the bolt or its cross threaded in there. A nice pipe wrench or vise grips help good too.
Old May 14, 2006 | 12:29 AM
MAP Gas?
Tried the pipe wrench and the vise grips. The M8 bolt is now only 6mm in diameter because it's been chewed off so much.
Old May 14, 2006 | 12:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Propane
Old May 14, 2006 | 12:33 AM
Yeah. A torch was my next idea, but I'd have to get my hands on one first.
Old May 14, 2006 | 02:01 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
When I busted the hold down on my Caprice, I just cut it off to get the batt. out, then filed down 2 "sides" on the hold down bolt shaft to give the vice grips something flat to bite on. Heated up the threads nice and hot and it came out fairly cleanly. Junkyarded a new hold down.
Old May 14, 2006 | 02:02 AM
That's a good tip.
Old May 14, 2006 | 11:56 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I tried propane and still am having NO luck. Stupid rain isn't making things any easier. And I need a hold down before I take her to a track .
Old May 14, 2006 | 12:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If nothing else works, just drill it out.
Old May 30, 2006 | 08:12 PM
Never did try heating it up, since I didn't have anything to heat it up with. Right now it's mostly drilled out. I just have to re-tap. Hope that works okay.
Old May 30, 2006 | 09:12 PM
Change out the battery tray. Call the dealer.
Last time I bought one, it was like $8. That was a long time ago, maybe they're twice that now; so what? Still mighty cheap, compared to all the rest of that hassle.
Old May 30, 2006 | 10:09 PM
I don't know what car you have, but my battery tray is part of the car's sheet metal... welded on. I just finished up and actually got the remnants of the bolt out after working it for over an hour with an 8mm tap.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
billybob6110
Sep 23, 2015 01:30 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Dialed_In
Aug 20, 2015 01:45 PM
