learn about engine parts, etc??? help
Old May 11, 2006 | 12:28 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
im trying to save money by rebuilding my two engines, one a 305 and a 350, both tpi's... i bought books and dvd's to read and watch but they all assume that you know what bearings, cam bearings, sleeves, freeze plugs, rods, plates, etc.... i know basic stuff but nothing too deep. they talk about measurements and tools which i know i grasp after reading, but all these parts are outta my league.... i know i have to take em to a machine shop first and then bring bk home to rebuild... so can anyone direct me to books, websites, etc... anything that i can read that will explain in depth or in general what the internal parts of chevy small block are and thier purpose??? thanks...
Old May 11, 2006 | 12:45 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Here is a website that I have found helpful...
Howstuffworks "Under The Hood Channel"
I would also recommend purchasing a Haynes manual for your vehicle. They are roughly $15 and come in handy.
Other than these resources, I have basically learned alot from reading posts on Thirdgen.org and simply taking things apart.
Hope this helps!
Best of luck.
Old May 11, 2006 | 12:57 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i have the manual, but the books says dont remove this bearing or that bearing, or this cam sleeve, etc without a tool... just stuff like that i dont know about... i need and want to learn as much as i can about our blocks, internals and all... thanks again
Old May 11, 2006 | 02:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
For background information, check out the Internet and your local library's automotive section.
As far as specifics, usually when the book says don't remove this bearing or that bearing without a tool, it's because you actually need the tool.
You don't have a chance in hell of replacing the cam bearings, for example, without an installer tool.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
