best way
Old May 11, 2006 | 03:06 PM
bigmaciroc's Avatar
best way
my motor is locked up, where is the safest/best place to hookup my breakover bar to bust it loose?
Old May 11, 2006 | 03:26 PM
Crank socket on the end of the crank, after you pull off the crank damper. Or, one of those crow's-foot looking things that bolts to the damper with the crank pulley bolts, after you take the pulleys off.
DO NOT try to use the damper bolt itself.
Old May 11, 2006 | 05:29 PM
bigmaciroc's Avatar
k, iv got the actuall pulley off, but theres no bolt i can see, there is still something on it that was behind the crank pulley that is round and about the same size, do i need to take that off to get to the bolt?
Old May 11, 2006 | 05:33 PM
What motor is this?
Old May 11, 2006 | 05:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You're probably looking at the damper. But, if you've removed the pulley, you've probably already removed the crank snout bolt. I.e. if you removed 4 bolts to remove the pulley, the bolt you are looking for isn't on the engine anymore.
Old May 11, 2006 | 07:06 PM
bigmaciroc's Avatar
its a tpi, non of those bolts are strong enough for this
Old May 11, 2006 | 07:14 PM
Vader's Avatar
You could also remove the inspection/clutch cover and use a flywheel tool to turm that end. If you have the balancer removed, you should sese a crank snout sticking out of the lower hole of the timing cover.
Old May 11, 2006 | 07:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The whole idea behind "do NOT use the bolt" was to have you avoid using a bolt to turn the engine.
Using either what Vader mentinoed (via the flywheel), or purchase one of these 2 tools:
The first is the crow-foot tool that attaches to the damper, the second attaches to the crankshaft snout itself (damper has to get removed for this).
Old May 11, 2006 | 09:22 PM
bigmaciroc's Avatar
where can i get those?
Old May 11, 2006 | 11:09 PM
Vader's Avatar
Any speed shop, auto parts store (not chain stores, but real auto parts stores), catalogs, and several places online.
