Do I need to change lifters?
Old May 11, 2006 | 05:31 PM
Demon355's Avatar
I'm building a mild 305 and am using an LT1 cam with 1.6 pro magnum rockers. The specs are like .477/.489. Do I need to change the lifters or no? My stock valve springs good? These 081 heads we're on a 350 before this and are ported/bowl work.
Old May 11, 2006 | 05:32 PM
Put new springs on it. You're just ASKING for trouble, leaving the stock garbage on there.
The lifters will be fine though.
Old May 11, 2006 | 05:34 PM
Demon355's Avatar
Ahh yeah I was thinking that. Do you have any suggestions for new springs?
Old May 11, 2006 | 09:21 PM
That's not a real radical cam or anything, even with the higher ratio rockers, so springs shouldn't be too hard to nail down.
Any of the major cam mfrs entry-level springs (Comp, Lunati, Crane, Isky, Crower; not GM, not K-Motion) would do well. Comp 981 for example. Those will fit in the stock spring pockets, as will the basic 1.25" OD products from the other mfrs. Get the matching retainers and keepers, and an assortment of shims.
Check the installed height. You'll want to aim for the "spec" height of around 1.70".
Old May 12, 2006 | 06:00 AM
Demon355's Avatar
Sweet man, thanks for you're help.
db057
Sep 4, 2015 07:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Brendankup
Aug 30, 2015 01:46 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
