Starting Problem
Old May 13, 2006 | 12:17 AM
jwenn89GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.45 9 Bolt
Starting Problem
I have a 89 GTA with L98. Mods are an air foil, headers, no cat, AIR removed. Prom has been programmed to delete VATS and AIR. First time I go to start it, it's fine. Could drive across the country without a problem as long as I don't shut it off. Shut it off and try to restart, and it will turn over no problem, but won't fire. If I wait 5 minutes, and try again, it will start. Car has been sitting about 4 years with only occasional engine starts. In the last 30 days, I have replaced fuel pump, fuel filter, starter, alternator, MAF sensor, pickup coil, distributor cap, rotor, module, and ECM. Fuel pressure is around 42 and injectors check out on Noid light. Any suggestions?
Old May 13, 2006 | 01:53 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
During the no-start period, what is the engine missing? Fuel or spark?
Old May 13, 2006 | 01:31 PM
jwenn89GTA's Avatar
Car: '89 GTA
Appears to be getting both. After searching and reading a ton of posts, I'm wondering if my injectors are leaking after I shut it off causing it to flood and the few minutes gives the fuel time to evaporate. It has original injectors, multec I think from what I read. Seems they have a history of going bad if they sit. Any other possibilities?
Old May 14, 2006 | 12:31 AM
jwenn89GTA's Avatar
Car: '89 GTA
anyone?
Old May 14, 2006 | 02:03 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Does it start if you try a clear-flood start (plant the gas to the floorboard while you crank it over)? If the injectors are leaking, that will allow it to start up a little easier.
Old May 15, 2006 | 12:44 PM
jwenn89GTA's Avatar
Car: '89 GTA
No it doesn't. This has got me stumped.
Old May 15, 2006 | 12:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Check for spark and fuel pressure during the no start. Check fuel pressure after shut down for bleed-off rate.
Old May 15, 2006 | 03:23 PM
jwenn89GTA's Avatar
Car: '89 GTA
How long should it take to bleed down?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
