THE MIGHTLY IRONDUKE
Old May 15, 2006 | 06:39 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
ok well i just got an iron duke car for free so i thought what the hey. i am having some troubles with getting it started. it will start up the run for about 3 seconds then die. i can give it gas but the it runs really rough but the smooths out and will run fine after that. if it dies it has some trouble restarting it just cranks over and dosn't start till you let it sit for a while? any ideas on whats causing this. I got new plugs, gaped them, new air filter and checked all the wires. what else could be causing this. It is a TB car and i don't have a tuner either. any help?
Old May 15, 2006 | 06:56 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
check the fuel pressure, make sure the pump is running. Also, when it dies, verify spark. If none, it is ignition related... not sure of the particulars of the iron duke engine. If you want a very good iron-duke specific section try - S10Forum.com. The old s10's are Iron dukes.
InfernalVortex
Apr 20, 2021 11:31 AM
Gunner242
Dec 25, 2015 04:49 PM
sjorgens
Oct 1, 2015 07:54 PM
Gordonr1973
Sep 29, 2015 11:59 AM
mfp189
Sep 27, 2015 09:25 AM
