Car vibrates
Old May 18, 2006 | 05:41 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Car vibrates
Hi, I wonder if any of you knows what this is. My car gets this awful vibration when I'm cruising in overdrive and push the gas pedal a little further to go faster without stomping on it for a gear change. The same happens when going uphill and just apply a little more gas. It's like if the transmission needed to shift but it doesn't and the car starts vibrating. It's really annoying and I really don't know what could it be? Help please. Thanks
Old May 18, 2006 | 10:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
perhaps lugging the car, and it's detonating?
tranny mount, motor mounts...
hmm, yea, sounds like you're lugging the car, OD with slight acceleration (low RPM), going up a hill, without hammering the gas (ie, low RPM)...
Old May 22, 2006 | 10:39 AM
Car: 1991 GTA
It does it in straights too. It doesn't seem like it's coming from the engine. It come from the rear. Anyway, the car never behaved like this before.
Old May 22, 2006 | 11:02 AM
none's Avatar
Car: '83 T/A
Engine: 355
Transmission: BW T5
Axle/Gears: BW 3.27
If I were you, I'd check the rear end fluid then, just to be sure. A lot of the times, with "normal" cars if the rear end is doing something funny its related to the fluid.
Right before my 10 bolt blew I was getting some REALLY bad vibrations down the highway (pinion bearings blew up).
Old Jun 1, 2006 | 10:56 PM
payday684's Avatar
drivetrain vibrations
I have been having that same problem in my 92 rs... i have the t5 tranny but i would assume that my fifth gear is the same as your overdrive.... i am going to check the fluids in my rear axle now.... it happens to me when i am going about 40 mph in 5th gear and i ease onto the gas... let me know how things turn out with your car... maybe it can relate to mine
Old Jun 1, 2006 | 11:20 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Make sure if you do change your gear oil you put in posi additive if you have a LSD.
Also, inspect your U-Joint bolts on your driveshaft. If you have a damaged U-Joint or a missing bolt, etc, or whatever, then you might get some wicked vibrations...not to mention your driveshaft could pop off while driving, and possibly do some damage.
Old Jun 1, 2006 | 11:53 PM
Maverick_IX's Avatar
Car: 1991 Chevrolet Camaro
Engine: GM 5.7L H.O. 350HP
Transmission: Rebuilt 700r4/Shift Kit/Servo
Definitely sounds like its not downshifting soon enough. Make sure the TV cable is tight enough and adjusted properly. The sound is just the motor lugging, driving in D when under 45mph obviously stops it, but is just band-aid and you are ignoring the real cause.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
