Timing
Old May 21, 2006 | 05:46 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
Timing
does any one noe what the original timing setting was on the 84 camaro z-28
Old May 21, 2006 | 08:07 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
sure...
What engine?
Old May 21, 2006 | 09:03 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Can you tell me for both the 305 and 350??????? if Possible please..........
Old May 22, 2006 | 02:53 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
84 camaro z-28
305 and 350
A stock '84 Z28 would have only had a 305, either 4 bbl LG4, 4bbl L69 (no crossfire anymore right?)
0 or 6* BTDC IIRC. But I think that's a meaningless stat, use what helps the motor run best now.
Old May 22, 2006 | 11:33 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
haha, yea. the 350 was never an option.
Just the duke, V6, lg4 (305) and l69 (305ho).
If its a true Z28 it could have only been the LG4 or L69 engine.
Check the sticker on the rad support with all the tuneup info
Specs are usually meaningless, just somewhere to start at. like sonix said set it wherever it runs best!
Old May 22, 2006 | 05:37 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Its the z-28 H.O......... so yeah its the 305 but now i got a 350 out of a 77 350 chevy truck
and the sticker isnt there anymore it faded and tore off
Last edited by Chevyman84; May 22, 2006 at 05:41 PM. Reason: Automerged Doublepost
Old May 22, 2006 | 05:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, so you're setting the timing on the 305 or 350? Either way, try 10* base timing, with ported vacuum on the distributor for now. It should run ok.
Then go get yourself an MSD 96001, and re-curve your timing to suit your needs.
Old May 23, 2006 | 12:15 AM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Yeah i have it set right now at 10.......... so im ok then???????????
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
