IN TROUBLE....
Old May 22, 2006 | 04:57 PM
87gtaJOLENE's Avatar
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
IN TROUBLE....
Alright, new ignition components, set my spark timing at correct mark, REPLACED IAC motor, REPLACED fuel pump relay, WHY IS MY CAR STILL RUNNING BAD?
I would start my car and it would sit real low at 300 rpm and shake. As soon as I hit the gas the rpm sits at normal and the car runs fine. Then after 10 mins, the rpm sits at 1300-1500 (tooo high). SOO then, I took the car for a drive and suddenly the car slowed down and the gas pedal got really hard. If I tryed to speed up, the engine would make a big poping noise (backfire??) and wouldnt allow me to accellerate. . Then a miracle struck me. My engine light finally came on and I was anxious to see what it would say... and it said code 33... MAF code.
Is my MAF sensor toast? Is what I described above symptoms of a broken MAF sensor? I want to make sure before I spend $200 on a new one. What do you guys think?
GTA Sammy
Apr 22, 2009 12:31 AM
duster70
Oct 18, 2008 07:06 PM
91transamGTA
Sep 6, 2006 08:10 AM
