taking a timing gear drive set off? wtf?
Old May 24, 2006 | 08:42 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
How in the hell do I get the gear drive off? is it like pressed on the cam or what? HELP!!!!
Old May 24, 2006 | 08:46 PM
MKnight's Avatar
Good question, I wouldn't mind knowing as well.
Old May 24, 2006 | 08:51 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Just take the three bolts out and remove it.
Old May 24, 2006 | 08:57 PM
flrtin1's Avatar
Engine: S/B
Are you referring to the cam button sticking out of the gear it is a separate piece
Old May 24, 2006 | 09:31 PM
I took the three bolts out and it wont come off.....should I tap on it with a rubber hammer?
I know the bottom gear is pressed on but what about the bottom?
Old May 24, 2006 | 09:33 PM
flrtin1's Avatar
Engine: S/B
I would gently pry from behind it alternating sides it should not take to much to pop it off
Old May 24, 2006 | 09:35 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
hmmm, yea the bottom is definately pressed but the cam gear shouldnt be...
I would try giving it a little love tap with a rubber mallet or the like and see what happens. it should have fell into your hands when you pulled out the 3 bolts...
Old May 24, 2006 | 09:51 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Nah, mine went on the same way...difficult. I wouldn't hit it with a hammer. I had to turn the gear set back and forth litle bit to find the sweet spot where they are loose. Basically, there is a little gap between the teeth and when they run/turn, it meshes and presses to one side more. If you can turn the gear a little bit...not much, itll slide right off. If its too much, I guess you can pry and hammer on it, as long as youre dumping it I guess.
Old May 24, 2006 | 10:49 PM
well it came on the engine I got and I read that gear drives do not work with knock sensor motors so Im having to remove it...its brand new..I'll just put it on ebay.
Old May 25, 2006 | 07:17 AM
I got it out guys......it was just on there real tight..the little button on the end of the cam had a good hold on it....thanks!
Im just curious..how is this thing timed? there are no marks on the gears...only one way to put them on....so how would you set the gears up...just get it at TDC and put them on...how would you advance or retard?
Last edited by Wishmaster's87IROC; May 25, 2006 at 07:20 AM. Reason: Automerged Doublepost
Old May 25, 2006 | 11:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are marks on the gears. Check both in the picture at about 1 o'clock. The dot on the tooth.
RBob.
Old May 25, 2006 | 03:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
BTW theirs lots of speculation wether the gear drives actually 'trick' a knock sensor or cause excessive cam wear.
Old May 25, 2006 | 03:50 PM
which means what? I could have used the gear drive?...do you know of anyone using a gear drive in a computer controlled car? and it not affecting the knock sensor? if I knew for sure!.....hell I would just put it back on but then again I would rather be more sure about a regular double roller...noise of a gear drive would probably get to me after a while.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midge54
Jan 29, 2017 07:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
