clunk
Old May 25, 2006 | 07:54 AM
camaroman350's Avatar
Car: 92 Camaro RS
clunk
I just put a 350 in my car a few weeks ago.What a big difference from the 305!I went 2 take off yesterday and herd a clunk it felt like my seat broke.Has anyone ever had this problem.The transmission mount isnt broken.Its like something broke on the drivers side. help please
Old May 25, 2006 | 08:45 AM
Upper shock mount?
Old May 25, 2006 | 11:16 AM
Raiderfan's Avatar
Car: '92
Trans mount....
Old May 25, 2006 | 12:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How did you verify that?
Old May 25, 2006 | 12:52 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I had this problem before on my old 86 IROC, found that the motor would jump, and found out why my motor mount did not have a bolt in it; the upper mount was off a 6.2 DIESEL, on a 305HO, I was like wtf??? but was able to get a bolt in there, too much work to switch out the motor mounts.
Old May 25, 2006 | 01:20 PM
Car: 92 Camaro RS
I checked it plus when its broken the stick comes up (5speed)
could it possibly be a shock
Last edited by camaroman350; May 25, 2006 at 01:24 PM. Reason: Automerged Doublepost
Old May 25, 2006 | 02:28 PM
five7kid's Avatar
Okay, that's the first mention of a 5-speed.
I had a rear upper shock mount poke through. Good place to start looking.
Old May 25, 2006 | 02:34 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Bad torque arm bushing or broken torque arm bracket?
Old May 25, 2006 | 08:24 PM
Car: 92 Camaro RS
when you push down on the back of the car it humms and sqeeks loud by the springs
Old May 25, 2006 | 08:46 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
make sure the squeaking noise isnt the brake lines rubbing..i thought my shocks were bad because i heard a squeaking nose, turned out to be the brake lines
Old May 25, 2006 | 10:44 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Rubbing brake lines arent fun, and neither is flying uncontrollably through an intersection suddenly...that was maybe the singlemost scariest moment of my life.
In case that one went over your head, rubbing brake lines = hole in line = loss of fluid = partial loss of brakes...unless you pop every brake line going to ever wheel, then you have zero brakes, lol.
Old Jun 17, 2006 | 09:00 PM
Car: 92 Camaro RS
THANKS GUYS it was the torque arm bracket right after i heard the loud cluck i parked it so do you think i could have damaged any thing else?will my springs quit skreeching when i push down on the back of the car? just asking cause i havent replaced it yet
F-body driver
Mar 6, 2023 11:44 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
BlackBoulder
Aug 11, 2015 11:15 PM
