retro-fit roller
Old May 25, 2006 | 06:50 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
retro-fit roller
I have a non-roller block and I would like to go with a roller cam. Would a retro-fit roller cam and roller lifters do? What else would I need to convert to a roller cam.
Old May 25, 2006 | 06:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Retrofit roller cam, retrofit roller lifters, thrust button for the timing set, and new pushrods.
Old May 25, 2006 | 07:03 PM
kairles's Avatar
Engine: 383/LGX
I have a new double roller timing chain for a non-roller block, would I be able to use it or would I need another style chain?
Old May 25, 2006 | 07:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That is the style you will need.
Old May 25, 2006 | 09:12 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
And about $850 for new pieces.
Old May 25, 2006 | 10:54 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I was just going to suggest getting an actual roller block rather than trying to retrofit. Hey, they're cheap.
Old May 25, 2006 | 11:31 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
I retro fitted a non-roller block on my last build and will never do it again! I guess it really depends on the use of the car but if you don't plan on it being an every day driver you don't need the roller cam. Sure better ramp rates, smoother operation, and less valve train friction is nice but remember, guys made plenty of power before this was an option and they still do today. Save your money, use a non-roller cam, and buy yourself a turbo. Trust me, you will be a lot happier that way. I know I would have been.
Old May 26, 2006 | 12:01 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
terrell what u doing wit a sbc gen 1?
Old May 26, 2006 | 12:28 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure, but find me a 400 roller block.
Old May 26, 2006 | 12:54 AM
kairles's Avatar
Engine: 383/LGX
I have a roller block in my T/A but it has 150k miles on it. I also have a non-roller block with 20K on it. I was gonna put a roller cam it it and have it ready to go in when the stock motor dies. then I'll use the roller block and maybe I build a 396 or something if I don't sale it
thanks for the info everyone
TraviZ don't worry the Iroc is still getting its turbo genIII
Old May 26, 2006 | 09:49 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm currently doing a retro-roller swap on my 400....Just look below for the post titled "oil leak turned retro-roller project". If you have any Q's PM me!
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
