Can I use 1.6 rokers on a stock engine to get more lift?
Old May 26, 2006 | 05:55 PM
R3500's Avatar
Just wondering...I put a 1989 IROC TBI 305 in my 88 Chevy 2wd truck. The roller block has no towing power (but runs great). I have been told that the standard non roller truck 305 had better lift/duration specs than the 305 Camaro roller block. It's a pain trying to find a low rpm/high torque cam kit for the roller block...seems like everyone sells non roller cam kits!!
So.....could I replace the OEM 1.5 rockers with aftermarket 1.6 rockers to get a bit more lift and most importantly...more towing power.
Just a thought..
thanks
Old May 26, 2006 | 06:01 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
You will have to measure the valve guides. it shouldnt be a problem unless you already have a mild cam.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
happyhapka
Aug 15, 2015 04:42 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
anesthes
Aug 8, 2015 09:37 PM
