Just how far can vortec heads be milled down?
Old May 28, 2006 | 07:32 AM
HuggerI-ROC's Avatar
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
Hi,
I have a set of Pro topline vortec heads for sale
and I have a buyer wanting to know if the 68cc chambers
can be milled down to 58cc chambers.
here is the rest of what the head are assambled with
https://www.thirdgen.org/forums/engi...=1#post2909030
Thanks for any help, JR
Old May 30, 2006 | 01:56 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Generally you want to avoid flat milling a chev cylinder head more than about .060"
At that point you'll be real close to the intake valve seat. Make sure you get paid in full before you mill your heads for the buyer, as there are lots of tire kickers out there. May aftermarket heads have thick decks but the intake valve seat is usually still the physical limit. "Angle milling" will allow more metal to be removed but requires correcting the intake face angle and head bolt holes be redrilled. There are may buyers for these heads. I'd find one that wants a 64-68cc head as is and let that buyer find some 305 heads or corvette l98/ZZ4 heads
Old May 30, 2006 | 02:22 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Edit
HAHA didnt realize you said Pro topline which already have thick decks. Then what F' Bird said.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
