IS THIS A GOOD MOTOR????!!!!
Old May 31, 2006 | 04:25 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i want to build up a motor to put out between 400-500hp. found a block not far from my house for $75. its a mid 70's 350 2blt main and a 2 pieace rear main seal.just wanted to see ur input on it.
Old May 31, 2006 | 04:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that would be your basic run of the mill vanilla block. Nothing special, good or bad about it.
You can build it up to 500HP, it's all about what you put in it.
Old May 31, 2006 | 05:43 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
depends what condition the block is in.
It could be a junk block thats been cracked or it could be perfect and just need to be align honed and cleaned up!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
cstrobel65
Aug 15, 2015 10:19 AM
fonzie85
Aug 13, 2015 11:50 AM
slade5612
Aug 11, 2015 07:19 PM
squiggy2
Aug 9, 2015 09:30 PM
