Vapor lock problems
Old May 31, 2006 | 11:10 PM
MKnight's Avatar
Vapor lock problems
Ok I installed a new gas cap today. I have a brand new carter high flow pump. I still seem to have some vapor lock problems as when I take the gas cap off I hear sssshhhhhhhhhh like there is built up pressure. I think it may have something to do with the fact that I removed all emissions stuff, like the charcoal canister. I have a steel line that used to be the return line for the old pump, I capped that off and I have another steel line that was connected up to the charcoal canister. Can anyone think of anything else?
Old May 31, 2006 | 11:14 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
the tank vented through the charcoal canister that's what it's for. Did you replace the gas cap with a vented cap?
Old May 31, 2006 | 11:17 PM
MKnight's Avatar
Probably not. I just went to the local shop and asked for a new gas cap. I need a vented cap?
Old May 31, 2006 | 11:37 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I'm pretty sure you do if you capped the vent line from the tank. Otherwise It'll just build up pressure and choke out your fuel pump.
Old May 31, 2006 | 11:39 PM
MKnight's Avatar
What about just uncapping the return line ?
Old May 31, 2006 | 11:45 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
well then you have gas fumes coming out in your engine bay or under your car, two places where theres a possibility for sparks. I remember a few years back a guy had a picture showing how to vent a gas camp it was drilling a hole in a certain spot. But i don't remember where, sorry. Maybe if you do a search for charcoal canister removal or emissions removal. Wish I could be more help.
Old May 31, 2006 | 11:46 PM
MKnight's Avatar
Thanks, no worries you have been extremely helpful.
Old May 31, 2006 | 11:50 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I've had this happen on every third-gen bird I've owned. I thought it was normal. I've also never removed any emissions stuff. Are you NOT supposed to hear that sucking sound when you take the gas cap off after driving it on a hot day???
Old May 31, 2006 | 11:57 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
nevermind, check this thread out-
https://www.thirdgen.org/forums/tech...ght=vapor+lock
looks like your issues (and mine) are normal.
Old Jun 1, 2006 | 12:02 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
there's two different pressures gunner the one like you have and in that thread the one like Firebat has. I'm thinking MKnight might be having the second one. My 87 had the second one my vent line was clogged. So MKnight drive it, if it stalls from to much pressure then you know your problem. If it doesn't well you don't have a problem
btw gunner are you a member of daytonfbody.org? If not check it out it's in your area.
BRoss99
Aug 10, 2025 05:08 PM
someone972
Aug 30, 2015 12:52 AM
neekolzun
Aug 24, 2015 04:59 PM
CORV3TT3
Aug 23, 2015 11:26 AM
g.l.mos
Aug 22, 2015 12:02 AM
