steam at the morning
Old Jun 5, 2006 | 03:05 PM
rscaracas's Avatar
Car: Camaro RS 1991 305 TBI
Engine: 305 LO3
Transmission: automatic
Axle/Gears: stock
Hi guys, several days the car expulse steam ( no all days ) what do you think? ( excuse me for my bad english,but iam learning a litlle beat)
Old Jun 5, 2006 | 04:26 PM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
Transmission: 700 R4
Axle/Gears: 3.23 I think?
Radiator leak? or is it coming from the tail pipe? If it is...you blew a head gasket.
Old Jun 5, 2006 | 05:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If its coming from the exhaust its just condensation unless it does it all them time, in which case a blown headgasket is suspect
Old Jun 5, 2006 | 06:40 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Can you try to explain this a little more? Is it steam or smoke? Where is it coming from? If it is coming from the tailpipes, what color is it? Is it only when you start the car?
Old Jun 6, 2006 | 06:50 AM
rscaracas's Avatar
Engine: 305 LO3
Axle/Gears: stock
steam
Hi, is steam.it is coming from de tail pipes,is only when the car are cold (at the morning ,we have in Caracas 23 Cº at 90% relativity humitdly)the color is white like steam.Other ask: which are the correct R.P.M.at ralenti?I have aprox 500/600 RPM.when the car is hot and 1000 when the car is cold. Thanks a lot for your help and excuse me for my uggly english
Old Jun 6, 2006 | 06:55 AM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
that rpm sounds about right, if it just comes out in the morning and you dont see the steam after that, its just condensation burning out of the exhaust, my car does this a lot too. just to be on the safe side, keep checking your oil, make sure theres no coolant in it. i think its just condensation though, you should be fine..
Old Jun 6, 2006 | 07:28 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
check the torque on your head bolts I had this problem in the morning and I took of the valve covers and redid the torque and presto- no more smoke.
there is no such thing as condensation in the cylinders. your head gasket is sealing when it is hot and letting just a wee bit of coolant in the combustion chamber over night.
As far as your english is concerned there are many illegals in this country who have been here for ten years or more that do not even attempt to learn the language of the land. Keep it up and know that most of us are just happy to see people trying
Old Jun 6, 2006 | 07:47 AM
rscaracas's Avatar
Engine: 305 LO3
Axle/Gears: stock
To all guys: thanks a lot for your help
Old Jun 14, 2006 | 08:32 PM
rscaracas's Avatar
Engine: 305 LO3
Axle/Gears: stock
steam at morning
Hi ! I think my problem is over! :the radiator R.I.P .I put a new one and no problem ( excuse me for my bad english ,but I am learning a litlle beat) the old radiator its leak.Today no more steam or water consume,thanks a lot for your help and tips!
djmarch
May 8, 2016 11:32 AM
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
RedLeader289
Sep 23, 2015 06:50 AM
sahlomonic
Sep 20, 2015 07:15 PM
