Small duration + high lift = ???
Old Jun 6, 2006 | 01:31 AM
CamaroX84's Avatar
My cam right now is 230/236 @ .050, with .510/.520 lift. I'm putting on 1.6 rockers before I head up to the track, so it will be .540/.550 lift on that duration (maybe add 2-3 degrees because of the rollers). To me that seems like a lot of lift for those duration numbers. Do you agree? How does that affect the performance of the motor and how does it shift the power band?
Old Jun 6, 2006 | 01:42 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
No way. My cam is 219/219 560/560
Old Jun 6, 2006 | 02:11 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
My cam is 236/242, 614/629 less the 16/18 lash.
Old Jun 6, 2006 | 03:08 AM
Super_GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
Are those cams hard on valvetrain parts? I have a 230/236 .596 .571 114lsa going into my bird. Someone told me I was going to be breaking parts. Should I have to worry about this?
Old Jun 6, 2006 | 10:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it's hard-er on parts then a tamer cam. You get more power, with less high duration drawbacks. Instead of the cam lasting 150,000miles, maybe 80,000....? It's not just the high lift/duration, but the high pressure springs that you need to keep the lifters on the cam, that wear it out sooner.
Old Jun 6, 2006 | 11:08 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
My cam is a solid roller. I use a stud girdle and have Comp 954 springs. The springs have 237 lbs on the seat and 537 open.
Old Jun 6, 2006 | 03:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
The springs I run are not as high as the post above but are around 140 on the seat and 414 open. I also have Trick Flow rods, Comp pro mag rockers, titanium locks /retainers, and surprisengly the stock but cleaned 88K mile roller lifters.
Old Jun 6, 2006 | 03:52 PM
CamaroX84's Avatar
Yeah I'm still running the stock 90K+ roller lifters. From what I've read they last almost forever.
beastin91rs
Oct 9, 2015 07:38 AM
blackroc68
Sep 1, 2015 08:01 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
mz92274
Aug 25, 2015 08:47 AM
bdads
Aug 24, 2015 06:01 PM
