fan switch
Old Jun 6, 2006 | 01:36 PM
91TG's Avatar
Car: 91 Camaro Z28
Engine: 350 L98 TPI
Axle/Gears: 3.23 posi
fan switch
finally got to drag my 91 Z last weekend for the first time since I've owned it (at least on a lagite drag strip). It was 90* plus and the engine was at 235* in the staging lanes. Would like to know if there is a way to add a switch to run both fans while staging to keep the temp at 195*and turn them off before racing so they work run as normal on the street?
91,000 orginal miles, ran 14.6 and 96 mph on street tires in the heat, good bad or ulgy? K&N's and a cat back system without the cats are the only mods. 60 ft time was around 2.8 and 2.9. had to really roll into the throttle and still had trouble hooking up
thanks
Old Jun 6, 2006 | 06:39 PM
3rdgenstm's Avatar
Car: ‘92 Z28
there are a few aftermarket switches to do what you want.
14.6 is decent for a stock iron headed L98--IMO.
Old Jun 6, 2006 | 08:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Change the switch out completely for a cooler one... I got one from Painless. Its rated at 200*on/180*off, but in reality its more like 210*on/195*off. I know that because I have a machanical temp guage that is accurate.
But it fits into the same hole in the head that the factory switch does, and only requires you to chop off the goofy factory connector for a female spade connector.
Works great for me, but the only problem I have is that, in the staging lanes, my single electric fan (thats also not close enough to the rad) doesn't move enough air to cool it down enough to turn off the switch when its just sitting there idling, which would lead to me racing with my fan on. To get around this, I put a simple on/off switch in the middle of the wire to the fan switch sensor. That way, if the fan is on when I roll up to the burn-out box, I can manual turn off the fan.
With dual fans mounted properly with the rad (unlike mine, which is too far away from the rad to work properly) you probably will not need the manual switch like I have, but that is how you do it if you decide you do want it.
Old Jun 8, 2006 | 06:33 PM
91TG's Avatar
Car: 91 Camaro Z28
Engine: 350 L98 TPI
Thanks for the tips. I have 2 fans, one works with the temp sensor and the other turns on with the air conditioning. I think the factory setting of 235* to turn the one fan on is to high and I should replace it with switch with a lower limit (thanks Air_Adam). However, what I was getting at was being able to manually turn both fans on and off with a switch while in the staging lanes if needed and have them work normal when the switch is off(for the street).
Old Jun 9, 2006 | 07:42 PM
Air_Adam's Avatar
My switch works just like you are asking, except you can't turn them on manually... only the proper temp wil turn them on. You can only turn them off manually.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
