speedo not working
Old Jun 6, 2006 | 06:04 PM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
speedo not working
I let my brother borrow my car for prom awhile back and somehow the speedometer broke while he was driving it. Now it just reads 0. Im not sure where to start trouble shooting or how to test to see what part is borken. Its an 88 GTA. Any Ideas would be much appreciated.
Old Jun 6, 2006 | 06:10 PM
86redtransam's Avatar
Car: 1986 red trans am
Engine: 305- JE pistions, edlebrokc intake,
Axle/Gears: 373s
look on your tranny
Look on the driver side of your tranny im sure the cable just broke or came out the the hole on the tranny
Old Jun 6, 2006 | 06:29 PM
383GTABoy's Avatar
Engine: 383 4 bolt
Ill take a look tonight when I get out of work. That would be sweet if thats the problem
Old Jun 6, 2006 | 11:07 PM
Rastus's Avatar
I think that the 'Birds got electronic speedo gauges starting in '86, althoughI'm positive an 88GTA would have the two-wire VSS. If not, I'm sure someone will post up and correct me.
The teeth could have stripped, or a wire is loose, probably something not too awful bad.
Old Jun 6, 2006 | 11:15 PM
mgomez's Avatar
Car: '88 Trans Am/'96 Trans Am
Engine: L98/LT1
Transmission: 700R-4/T-56
Axle/Gears: 3.42/4.10
Gear probably popped out of the tranny, every T/A from '86 up had electronic speedo. I've had a similar problem. I'd check there 1st, it's a pretty quick check.
Old Jun 13, 2006 | 01:18 AM
383GTABoy's Avatar
Engine: 383 4 bolt
well I pulled it out tonight and no luck. It looked brand new. Perfect teeth and the plug even looked suprisingly clean for where it is. I followed the wires into the main harness and they dont look worn or anything. What else could the problem be. Has anybody ever had one go bad inside. I wanted to test it with a volt meter but i couldnt find mine.
Old Jun 16, 2006 | 09:41 PM
383GTABoy's Avatar
Engine: 383 4 bolt
Ok i got to plugging in diacom today and the ecm knows how fast the car is going but the speedo still reads 0. Does that mean that something in my digital dash is broken? Also I cant read my odometer. It is just blank and doesnt read anything.
Old Jun 17, 2006 | 09:42 AM
Rastus's Avatar
Well, IMO, it now sounds like something inside the speedo gauge is either loose or broken. You'll never know until you take it apart I guess.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
