how many wires should go to the o2 sensor
Old Jun 8, 2006 | 07:50 PM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
i found a lose wire that had pulled out of a connector hanging down by the passenger exhaust thought may be for the o2 sensor but could not get under far enough to tell if not o2 than any ideas
Old Jun 8, 2006 | 07:58 PM
Raiderfan's Avatar
Car: '92
1 Plug 1 wire as far as I know.
Some have an extension for the o2 so it might be a couple of plugs.
Old Jun 9, 2006 | 12:28 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Strange, My o2 is on the drivers side, but I have a pontiac! Should still be only 1 wire though.
Old Jun 9, 2006 | 02:13 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
i dont think it is to the o2 sensor it lookedto be pluged up now what
Old Jun 9, 2006 | 02:22 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
What colour is the wire?
Old Jun 9, 2006 | 02:24 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
green
Old Jun 9, 2006 | 06:22 AM
Fan switch
Between the #6 & #8 spark plugs
Old Jun 9, 2006 | 06:23 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Do you have anything that isn't working? Like air conditioning or fan speed?
First I would check the wire with a continuity tester with the key off and see if it's hot and then with the key on. Check for a knock sensor on the side of your block also.
Old Jun 9, 2006 | 11:51 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
thanks for the replies
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
Ironhead38
Sep 7, 2015 02:26 PM
