Water Temp gauge problems
Old Jun 12, 2006 | 01:16 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I have an 88 Camaro originally a v6. It has been swapped out in favor of a carbed 97 model 5.7 Everything has been rewired and runs great.
The water temp however doesnt work right. It has a new sensor, (cant remember if we used one from a 88 with v8 or v6). Sometimes when the car is first started the gauge works and seems to read acurately. But once you cut the switch off, it usually will start back up on 100 degrees and stay there not working.
To make a long story short, sometimes it works, sometimes it dont. Could it be just the gauge? Can the gauges be changed without changing the whole cluster? Thanks
Brad
Old Jun 12, 2006 | 01:46 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well first off the sensor has to be for the original motor of the car as to not run into calibration issues. So a 88 V6 sensor would be correct, im not sure if the V8 is the same, i would assume so.
The actual gauge can be replaced in the dash without replacing the whole cluster.
Old Jun 13, 2006 | 11:30 AM
3rdgenmaro's Avatar
Car: 88 IROC
I am pretty sure that the right sensor is used. I have put two new sensors in it so I am sure it isnt the sensor. So you think the gauge could be bad?
Ghettobird52
Jul 5, 2024 11:18 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
