Rotor question
Old Jun 20, 2006 | 02:41 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
Rotor question
Hey guys, how would you know which position to place the rotor if you did not mark its original position before removing it? Is there a way to coordinate the rotor position with the firing sequence by knowing which cylinder is due to fire at any given time?
Thanks alot.
Old Jun 20, 2006 | 03:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The rotor only goes on one way.
If the distributor has been removed, you can turn the engine over to TDC #1 firing, and then which ever terminal the rotor is pointing to is the #1 terminal.
Old Jun 20, 2006 | 03:50 PM
hihighost's Avatar
Car: 1987 Camaro
ah yes, that's what I meant, sounds good, I found it in the Haynes manual, thanks alot.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
