No spark
Old Jun 21, 2006 | 01:21 AM
mattmac1989's Avatar
No spark
I have a 1989 firebird with a 2.8 v6 and i'm gettin no spark the cap and rotor r fine i also just replaced the wires and plugs and i had the ignition module tested some one told me it might be the idle air control valve, does anyone else have any ideas?
Old Jun 21, 2006 | 09:47 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
The IAC makeing no spark ??? Sounds wierd to me .
K , you say you have no spark . Is there any comeing right off the coil ?
Old Jun 21, 2006 | 11:28 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
sounds like the coil... easy fix its right behind the engine towards passenger side if I remember correctly
Old Jun 21, 2006 | 12:41 PM
no spark
i havent checked to see if there is any spark off the coil so... i don't know really know how to check if its coming off the coil.
Old Jun 21, 2006 | 02:07 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Its been awhile since i looked at a v6 but if I remember correctly the coil has a square 4 prong connector disconnect it, turn the key and check for voltage going to the coil with a mutimeter. if you have voltage connect the connector (while the key if off so you dont get shocked) then check the other two by trying to wiggle the mutimeter lead into the back of it if you can if not you can slightly pierce the wire with the lead and read voltage then
Old Jun 21, 2006 | 05:55 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
check for power to the coil, the pink wire going to the cap(coil on external cars) should have 12 volts...
If that checks out, remove the module, take it to an autoparts store and have it checked, and reinstall with heatsink grease(thick white grease only!!!!)
If that checks out, replace the coil, they're like $10, big whoopty dooo... you could have worse problems...
If the coil doesn't do anything, you need a new pickup...
there are only a few parts to an ignition system, once you understand it, they are very easy to diagnose...
YOur worst case senario, would be broekn, or fallen off timing chain. I have worked on a 4.3 with the timing chain completely off, and the crank spun freely, and there was no spark, funny how that happens eh? Well he needed a bunch of new stuff, heads redone and the whole shibang...
Prey to the car gods for forgiveness from this....
Old Jun 21, 2006 | 08:10 PM
no spark
im gettin spark from the coil and the timing chain is fine... and the module is fine so i guess ill try the other thing
Old Jun 21, 2006 | 08:20 PM
also what do u mean by pickup i can't find it on the autozone or any parts store web site
Old Jun 21, 2006 | 08:24 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
wait a sec, you said you had spark at the coil? why are you checking for a pickup? the coil only shoots when the module tells it to, and the pickup tells the module when a cylinder is at TDC...
How did you test for spark at the coil? did you do the neighborly thing and borrow her kid to hold his hand at the coil wire while you spun it over?
if the coil has 12+ going to it, its powered, it stores energy, when the module is told a cylinder is at TDC ready for spark the module tells the coil to let loose, and it does.
call autozone and ask if they have part number dr132 in stock, if so, its $12.67!
Last edited by 12SecondTA; Jun 21, 2006 at 08:28 PM. Reason: Automerged Doublepost
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
