Having problems please help
Old Jun 21, 2006 | 04:16 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
Hey i have an 85 z28 camaro and have been having a problem with my car. the problem is that i hit about 2500 rpm and i lose power to my car then the oil preasure is also goes down to about 30 psi. what is the problem and what do i need to do to correct it. it is also a stock motor. so please let me know what to do i just replaced the oil and has not helped.
Old Jun 21, 2006 | 04:25 PM
kjvail1204's Avatar
Check your spark, get a spark tester and leav it in neutral and see what the spark looks like it should be a purple if its yellow that could be it. The pressure drop could be due to ethier a bad gauge or the loss of ignition. Dont rule out that it could be the old pump but thats usually takes a while to go. How many miles are on the car, is your tach actting up at all.
My guess would be somewhere in the igniton for the loss in power, run it at night with the hood open, have someone put it up to the RPM's you lose power and see if you see any sparks (so do it without any light around) check all the wires look under the cap see if the rotor is broken ir worn down.
Old Jun 21, 2006 | 05:05 PM
85LT4Z28's Avatar
ok i will check that. the car has at least a 130,000 miles on it. there is no metal shavings in the oil or anything like that but its weired cause at night the problem seems to happen more as well like its running to cold or something cause usualy in the day i dont have that problem.
Old Jun 21, 2006 | 05:12 PM
kjvail1204's Avatar
Never heard of a car running to cold unless its like freezing outside, you can do the spark test even with a screw driver. Check off the coil first (coil to distributor) then start at the first plug and go
Old Jun 21, 2006 | 05:45 PM
85LT4Z28's Avatar
ok i will check with the screwdriver tonight. how hard is it to replace the oil pump on that car or the distributor
Old Jun 25, 2006 | 03:39 PM
85LT4Z28's Avatar
ok i was driving it around the other day and noticed if i dont put my foot down to the floor i dont get the hesitation but when i put my foot to the floor i get hesitation... what may be causing this weired behavior.. the oil preasure luckly has been going back to normal any and all advice will be much appreciated and if someone has had the same thing let me know what to do...
Old Jun 25, 2006 | 06:23 PM
kjvail1204's Avatar
its either fuel delivery or spark how was your spark at that RPM
Old Jun 28, 2006 | 10:50 AM
85LT4Z28's Avatar
well i ended up replacing my fuel filter and my fuel pump and i still have the same problems... like i said it only does it at wot and no other time that is why i am so confused.. any more advice will be helpfull
Old Jul 22, 2006 | 01:28 PM
kjvail1204's Avatar
Hey bro jsut trying to find out if you fixed the problem, if so post what you did to fix it so others can benifit from your experiance
Old Jul 22, 2006 | 03:23 PM
85LT4Z28's Avatar
havent fixed it yet still working on it havent had the money for the distributor and no codes are pulling up on it so i am going to replace the distributor and wires and if that dont do it then the carb then i will dump this motor and buy a 350... but want to save this one first
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
