car shakes and misses!! please help
Old Jun 22, 2006 | 07:43 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
this just started today, when the engine idles it will miss 2-3 times every 5 seconds. then when i hit the gas at idle the hole car shakes from vibration. when i drive it it will continously miss through the entire rpm band. i checked the timming and it is steady at 6* adv. coil,plugs and wires are all about 2 months old. any help would be nice.
Old Jun 22, 2006 | 09:30 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
When you replaced the wires, were you careful to route them far away from the exhaust manifold? If one of them (or more) got burned and they're arcing, the car will misfire.
Old Jun 23, 2006 | 10:29 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
are you sure you did not cross up some wires.....
Old Jun 23, 2006 | 09:08 PM
i fixed it today, it was a bad distributor cap thanks though
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
