need help installing power steering pulley
no, dont use a hammer.
They make a special tool to do it. It threads into the pump and pulls the pully on.
You will ruin the new pump if you smack it with a hammer.
Get the right tool and it will be a piece of cake.
Car: 1991 Z28 (sold)
i was jk about the hammer....yeah i got a pulley remover/installer kit and i didnt realize i had lost the screw for installing it untill i found it lying on my garage floor. so i figured out how to get it on...how do i know when to stop turning? i dont want to overtighten it if thats possible. right now the pulley is in the same place on the shaft as it was before i took it off, but i can keep tightening it if i want...maybe it wasnt all the way on to begin with?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Originally Posted by rwdtech
so how exactly do i do this? should i use a hammer? lol
They're usually set up so that the pulley presses on to where the hub is flush with the end of the shaft.... pretty hard to screw that up in the factory, which is what the factory really cares about the most, so that's how they do it.
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Navy8125
Aug 22, 2015 07:13 PM
