Oil pan replacement with T-5
Old Jun 24, 2006 | 09:12 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Is there anything different about replacing your oil pan with the engine and trans in the car if you have a T-5, or is it the same? I just thought I would ask before I tried. Thanks for any replies guys.
Old Jun 24, 2006 | 09:40 AM
Engine: LB9, LB9
Also guys, while looking at pans, I came across one that I seem to like. It is part #MIL-30702 in Summit. It says it is supposed to be a stock replacement oil pan, but as I was reading the notes to it, it says that it requires a thick front seal. Would this still mean I could get away with just simply swapping the oil pan out and not messing with anything but the oil pan gasket? Also how hard is it to swap the pick-up on these engines?
Old Jun 24, 2006 | 10:20 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
It takes some finess but it can be done... Its the same oil pan I have.
You shouldnt have to swap the pickups but if you do it there is nothing to it
Plus i have a T-5 and it worked out fine... Just use a one piece oil pan gasket with the metal spacers and you will be fine
Old Jun 24, 2006 | 10:23 AM
Engine: LB9, LB9
So the front seal thing is no worry?
Old Jun 24, 2006 | 05:17 PM
Engine: LB9, LB9
Just need a few more opinions before I tackle this please guys.
Old Jun 24, 2006 | 09:18 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
what is there to worry, did you look this up in the summit catalog? because it says you need an extra thick seal for the oil pan with a (*) which is a late 70's model I believe... it is an OEM pan that uses oEM gaskets
Old Jun 24, 2006 | 11:05 PM
Engine: LB9, LB9
You didnt notice any difference in anything from switching to this pan did you?
Old Jun 25, 2006 | 10:00 AM
Oil pans don't generally just up and need to be replaced.
Which makes one wonder: why are you doing this in the first place?
Has the smog pump been hacked off of your car by any chance?
Old Jun 25, 2006 | 10:58 AM
Engine: LB9, LB9
no, it is just so rusted, that if I pushed my finger on it hard enough, it would just cave in. All smog is still there.
Old Jun 27, 2006 | 06:22 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Why would you notice a difference? Its an OEM replacement
Old Jun 27, 2006 | 07:40 PM
Engine: LB9, LB9
Baffles
Old Jun 27, 2006 | 08:08 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
lol
O
E
M
Nothing changes
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
