Head / Cam Swap Checklist
Old Jul 4, 2006 | 12:38 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I am going from a stock 1990 MAP L98 motor with centerbolt 083 heads and roller cam and putting on a set of Brodix IK180cc aluminum heads and a Crane roller cam.
I am making a checklist so that there are no surprises, let me know if I miss anything:
-Heads (derr)
-Cam (derr)
-Gaskets
-Fluids (coolant, oil, have filters)
-Bolts? Can I just use the stock ones?
-Double roller timing chain and gear set
-Have all tools
-Paint, sandpaper, etc, for detailing purposes
-Spark Plugs
-Perimeter style valve covers
-Pushrods
Missing anything? I think since the stock lifters were roller lifters, I am going to re-use them. That and the rockers are getting re-used. I figure if I want to go up to a roller setup, ill just pop off the valve covers and do them at a later date.
Old Jul 4, 2006 | 12:57 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Looks like a starter list, things always seem to take a turn when working on an engine. Depending on what type of bolts you use, be sure to use new head bolts, and also since its a speed density you might need to do some computer management on that front. Make sure the hydraulic lifters dont collapse under too much lift, may be a hassle. Other than that looks good.
Old Jul 4, 2006 | 10:01 AM
Yeah, I plan on getting a prom from PCMforless.com burnt as well. I'll look into a set of head bolts from ARP, I suppose. Was kind of hoping I wouldn't need to get a set, I'm cutting it close as is.
Old Jul 5, 2006 | 09:52 AM
Bump. Okay to use the original head bolts, or should I get a set of ARP bolts?
Old Jul 5, 2006 | 12:57 PM
If you have the origional head bolts, they are junk as soon as you pull them out. The reason for this is the head bolts stretch, and as soon as you take that tension back off them they are as good as dead weight. In any case, unless its a lawnmower, you should use new head bolts. IMO.
Old Jul 5, 2006 | 04:43 PM
Thanks for the tip. Anyone recommend a set for a good price?
Old Jul 5, 2006 | 05:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I reused my stock head bolts. They're fine, they're not torque to yield (TTY) style bolts. Do a search on TTY if you're curious for more info. I used mr gasket head bolt washers though, helps spread out the clamp load etc. Just clean up the threads with a wire wheel, I used my bench grinder, as I had a wire wheel on that. Use thread sealant on all head bolts.
You can get new ones, $50 for ARP, or a little cheaper for GM or mrgasket ones, but if you're going to upgrade you might as well go to ARP ones. Like $10 more then all other brands and quality is on a totally different playing field. Inspect brand new ARP bolts, side by side with other, normal bolts. They're flat out amazing.
Old Jul 5, 2006 | 05:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
SBC head bolts (actually, all SBC bolts) are not torque-to-yield, so what ResurrectingZ said does not apply. They are only torqued to the elastic region, so as soon as they are untorqued they return to their previous state. Now, the head bolts on my Series II 3800 in the Bonneville are a different story, as they are torque-to-yield.
Old Jul 5, 2006 | 05:53 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
yeah, I was originally going to comment that you dont need to buy new head bolts, but a lot of people will argue that and I didnt want to steal the thread.
-Blair
Old Jul 5, 2006 | 06:43 PM
Thanks Sonix and five7kid, you guys always help me out, so I know you know what you are talking about. I'll clean them up and use them, since I am trying to stick to my budget here.
Will red Loctite thread locker be okay to use with these bolts? Or is that too strong/weak? Would you recommend Blue instead?
Old Jul 5, 2006 | 11:18 PM
My bad for the misleading info, I have always been under the impression to toss head bolts and get new ones. Someone slap me...
I should have saved my old head bolts, oh well. $50 down the drain.
Old Jul 5, 2006 | 11:20 PM
Eh, look on the bright side, at least they look pretty...if you can even get your head down there in the first place to notice them
Old Jul 6, 2006 | 12:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
mr gasket head bolt washers are like $5, if you can get them easy enough, i'd use 'em. I think they're worth it, while looking at the area that bolt clamps down on, on the heads, and how hard you're torquing them.
No loctite red/blue, thread sealant. "Permatex thread sealant with teflon" is what i've got.
Old Jul 6, 2006 | 12:52 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
You dont want to know how many times ive replaced head bolts thinking you had to. Then I learned, and it was glorious.
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
