A/C question
Old Jul 12, 2006 | 12:18 AM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
A/C question
i got a 89 305 camaro and i was woundering if i take off my a/c how much it would help me out because i want to do evey thing i can to help my littel 305
Old Jul 12, 2006 | 10:28 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Not a whole lot, the compressor weighs maybe 5 lbs, if you remove the condensor you'll free up a lot of airflow to the radiator, which would help keep the car slightly cooler.
As long as the air isn't on then it isn't exactly hurting your performance. Without engaging the magnetic a/c clutch the pulley is on bearings and freewheels with ease. Every little bit helps, but thats kinda like blowing against a hurricane.
Old Jul 13, 2006 | 01:06 AM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
k thanks
Old Jul 13, 2006 | 02:16 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If your A/C works properly, I personally wouldn't touch it. The gains you may net are outweighed by that "creature comfort", In my opinion.
Old Jul 13, 2006 | 11:18 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
I pulled my functioning A/C a few years ago. Like stated, no real gain. Been missin that A/C on these 100+ summer days.
Old Jul 13, 2006 | 03:25 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
well i live in Texas and it gets pritty hot but i steal think im going to take it off becase it just takes up so much room under the hood
Old Jul 13, 2006 | 03:32 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
what about talking my smog pump off will that help me out any
Old Jul 13, 2006 | 07:37 PM
pizza_guy's Avatar
If you don't have visual emmisons in your area, I don't see any real consequenses.
If you try to sell it one day, the lack of stuff may cause a problem.
Old Jul 14, 2006 | 12:04 AM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
well i can get the hook up on inspection stickers so i dont care about emmisions so would taking off my smog pump help me out any???
Old Jul 14, 2006 | 04:58 PM
25thz383's Avatar
Car: 92 Z-28
Engine: 383
a/c delete?
I would like to delete my a/c along with my smog pump but I can't figure out how to keep the tensioner or even how I would route the belt any help?
Old Jul 14, 2006 | 05:18 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
u can buy a a/c delete on ebay so u wouldent even have to do any thing with the belt
Old Jul 14, 2006 | 05:21 PM
25thz383's Avatar
Car: 92 Z-28
Engine: 383
thanks, is it just another pulley?
Old Jul 14, 2006 | 07:48 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Trust me, you will regret removing the a/c. In case you didn't notice it is HOT outside. Hopefully I will be moving north soon, and I will STILL have a/c!
Old Jul 14, 2006 | 08:15 PM
25thz383's Avatar
Car: 92 Z-28
Engine: 383
a/c removal
I don't drive it all that much seeings how saying it gets 12 miles a gallon is generous. Besides, I've cut, burned, and pinched myself too many times because of lack of room. If you roll down the windows and haul a** it cools right off inside.
Old Jul 14, 2006 | 08:32 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Not in Texas. I've had 2 cars with no a/c, man that sucked. I'm temporarily in Georgia and my a/c is a little weak in the Firebird so it still kinda sucks.
Frozer!!!
Jan 19, 2024 04:55 PM
greenyone
Aug 29, 2015 11:08 AM
redmaroz
Aug 16, 2015 11:40 PM
BikeFarm
Aug 11, 2015 11:35 PM
