Help with Pass Key!!
Old Jul 13, 2006 | 09:17 PM
Killergrl's Avatar
Car: 90 Camaro RS
Engine: 350 TBI
Ok so I got a '90 camaro RS, my key is in great shape (so it looks) but every once in awhile i go out to start it and i get nothing, no click, nada, the gauges move and fuel pump kicks on but that damn security light comes on and stays on! its really annoying because it just does it out of the blue. I just went out there moved it up 3 feet then came inside for 2 mins then went back out and now im stuck its doing it again!! i imagine that i need to buy a new expensive key for it but since the key looks in great shape, anyway is there anyother cause?!?! any secret cures from anybody!!?!?! let me know!
Old Jul 13, 2006 | 09:22 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
You looked at the little metal tabs on the key where the chip is and everything looked good right. Only reason i ask is because i had one where the metal tab was halfway broken off and the car would start somtimes. I had to wait 15 min or whatever the time-out is on the alarm sys before i could try to start it again. If you have another key i would try that first.
Old Jul 13, 2006 | 10:06 PM
Killergrl's Avatar
Car: 90 Camaro RS
Engine: 350 TBI
re
yea they are in excellent shape. even cleaned them up ( didnt really need it but hey worth a try!)
even did a resistance check on the key and it all checked out good.
Old Jul 13, 2006 | 10:26 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i think you'll find what you want here, https://www.thirdgen.org/vats
good luck
Old Jul 14, 2006 | 01:00 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
If your keys look like its in great shape then I would say your ignition cylinder isnt picking up the key resistance.Sometimes the wires running to the cylinder in the column start to come apart and lose contact.They move everytime you turn the key to start or run position so after many starts on/off the wires start to go south.I would suggest making a by-pass wire for added security for these times.I made one just in case..
Old Jul 14, 2006 | 10:39 AM
Killergrl's Avatar
Car: 90 Camaro RS
Engine: 350 TBI
thanks!
Thanks guys for the FAST responses!!! the bypass route sounds like the way to go! will let u all know!
Here's another one for ya: so you know on like EVERY 3rd gen camaro/firebird the drivers seat starts to tear then the wires start coming out......eventually making it so u get stabbed in the ribs everytime u get in?!? well after about 4 ripped shirts i bought some thick leather like covers BUT it has ripped through, took longer then the others but still im back to the beginning, any suggestions for someone that cant afford the new apolstery job (didnt spell that right!) and cant seem to find any seats in my area that dont have that same problem!
Old Jul 14, 2006 | 08:56 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
...eventually making it so u get stabbed in the ribs everytime u get in?!? well after about 4 ripped shirts i bought some thick leather like covers BUT it has ripped through, took longer then the others but still im back to the beginning, any suggestions...
Stay focused. Fix the PASS KEY problem.
Old Jul 16, 2006 | 01:44 PM
Killergrl's Avatar
Car: 90 Camaro RS
Engine: 350 TBI
fixed
Key problem fixed......back to the mile long to do list!!
Old Jul 16, 2006 | 01:51 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
get a big rubber tape and cover the tear,
then put a seat cover over them.
until i bought my new seats
my 29.99$ seatcover from autozone worked just fine for a year.
Old Jul 16, 2006 | 01:55 PM
Killergrl's Avatar
Car: 90 Camaro RS
Engine: 350 TBI
re
yep i got the same seatcover from autozone probably that u got! i was thinking about doing that just the other day i think that if i get pliers and bend that wire so it's not stabbing me then tape the crap outta it, it should be fine! i hope! just til i find some new seats 4 her!
Old Jul 26, 2006 | 09:11 PM
a91rs's Avatar
Car: 91 RS
Engine: 350 tbi
Killer, at leat tell me what the fix was for the key problem,,,Mine is doing the same thing, and sometimes have to wait up to 2 hours to get it started
Old Jul 26, 2006 | 09:56 PM
Killergrl's Avatar
Car: 90 Camaro RS
Engine: 350 TBI
re
if you go to https://www.thirdgen.org/vats
it tells you how to do it rather well!
2 hours is a long time though, that's strange. mine would just have to wait the reset time 15 mins or so......
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
darwinprice
17
Oct 11, 2015 11:51 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
