my 89 iroc wont start
Old Jul 15, 2006 | 12:27 AM
1989iroc-z/28's Avatar
Car: 89 iroc and 95 honda civic
Engine: 5.7 tuned port
Transmission: th700r4
Axle/Gears: 9 bolt 3:73
i have a 89 iroc that i have fixing up for awhile now and i'm at the end of my wits here help. hes what i have done so far it has new factory heads new fuel regulator net tps new iac i=new fuel pump new oil pressure switch new prom new ecm new plugs wires cap ect the was running fine then one day it started to bog like it wasn't getting fuel i twed it home and installed a new fuel pump the next day in started i was on the way to the muffler shop to put the exhaust back on and it died at the gas station if you pour gas in the trottle body it fires just fine the pump cycles but to me it sounds like the pump turns one then it starts to run backwards i really miss my car can some one help
Old Jul 15, 2006 | 12:43 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
injectors, distributors, etc etc..
engine codes?
Old Jul 15, 2006 | 03:13 AM
my car wont start
engine codes?
new injectors good distributor no codes wont run
Old Jul 15, 2006 | 08:40 AM
kcstoltzmn1's Avatar
Car: 1991rs camaro/intrigue 3.5 dohc mfi
Transmission: 700r
check for broken wires mine did that they run under carpet through rubber gromit to top of your fuel cell too somtimes the wires stretch or break mine broke there too short
Old Jul 15, 2006 | 09:42 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
check fuel pump relay
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
