How do you install an MAF sensor?
Old Jul 17, 2006 | 05:47 PM
Italiantank48's Avatar
Car: 1988 Chevrolet Camaro
Engine: 2.8 v6
2.8 V6 1988 Camaro, How do you install the MAF? Is it as easy as it looks and should be? do I have to do any calibrating like I did with the TPS or is it simply remove air intake, remove MAF from end of intake, put new one on and plug in?
Old Jul 17, 2006 | 10:30 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
remove old bad maf, replace, reconnect....
done....
sit back and drink a beer, but dont drive drunk!
Old Jul 17, 2006 | 11:33 PM
Engine: 2.8 v6
thought it was easy enough, I've done almost all the repairs on my car myself (recently though workin two jobs I just sent it to my mechanic and got some of the last touches done - oil change, coolant flush, TPS calibration.. general crap that's just time consuming but important..) and He tells me "you're pulling a bad MAF code" I know this. Can do it for $100 - says he. I know the part costs $50. And unless he's replacing/calibrating something I didn't know about it's certainly not $50 worth of labor in there. Are there other relays and such that might be causing the bad code? If so how do I check them? Would I use like a voltometer to see if the wire has the proper voltage, etc? I'm tired of wasting money on parts I probably don't need, but my electrical system has generally rotted to bejeezus and back so... I'm testing wiring as bad parts before more sensors..Relays are generally $10 or so, so replacing one of them rather than the $50 MAF would be preferable..
Old Jul 18, 2006 | 11:33 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
a bad maf code can be the relay and/or the sensor, be sure before spending $50....
Logan Bryant
Aug 27, 2015 11:52 AM
nuggie
Aug 25, 2015 01:27 PM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
mdtoren
Aug 16, 2015 05:45 PM
