sending unit thing?
Old Jul 18, 2006 | 08:17 PM
dillardracer's Avatar
Car: 1992 rs camaro
sending unit thing?
I'm in the process of swapping a 350 tbi from an '87 van into my LO3 '92 camaro. The 305 has a sending unit under the exhaust manifold on the passenger side head that has a wire going to it from the harness that plugs in with a little spike thing. The 350 has this blocked off with a plug. All the gages worked on the van before I tore it apart, because at first I thought it was for the temp. gage. I can't get the plug out at all to install the send. unit. Can I get away with not swapping this over? What is it for?
I'm going a/c, heater, smog delete too by the way, in case that sending unit is for the smog stuff or something.
Old Jul 18, 2006 | 10:05 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Does the Camaro have 2 radiator cooling fans?
I was thinking that unit you're refering to is a temp switch used to activate the secondary (radiator) cooling fan.
Old Jul 18, 2006 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Could be the knock sensor. Is it in the head or in the block?
Old Jul 18, 2006 | 11:13 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
It is a temp. sensor to tell the fans to kick on. It is not for the temp gauge. The knock sensor is located below it on the engine block itself passenger side.
POZ
Old Jul 19, 2006 | 09:26 AM
Car: 1992 rs camaro
Could I get away with not switching it over to the new engine if hooked the fan to a toggle switch? My car only has 1 fan.
Old Jul 19, 2006 | 09:46 AM
I would not do that.
All it takes is forgetting to turn the switch on ONCE to trash your motor. Is it worth that? Do you want to add yourself to the posts we've already seen here about "I loaned my car to my wife/GF/best friend/work buddy and they didn't turn on the fan and now I've got cracked heads/blown head gasket/whatever"?
Drill the plug out, and put the sending unit in, like it belongs.
Old Jul 19, 2006 | 10:40 PM
Car: 1992 rs camaro
Well, now I've got no other option than a toggle switch. I drilled a hole in the plug and busted an ez out off in it. Hopefully it doesn't leak.
Old Jul 20, 2006 | 12:44 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Pull the head off and do it right. You will regret it if you don't.
Old Jul 20, 2006 | 07:17 PM
Car: 1992 rs camaro
There's no way I'm pulling the head now, I've already got the motor and trans. back in, just gotta bolt all the crap back on it. I only paid $300 for the van that the drivetrain came out of and as bad as I'am at fixing cars, if I pull the head off there's no chance in hell my car will ever run again. Right now, I've probably got about a 40% chance of getting it running again. If not, it will go back out in the field and rust a little more till the next time I'm feeling mechanical.
Old Jul 21, 2006 | 09:40 PM
thepoz89's Avatar
Engine: 350, 355
is a cooling system pressurized? what do think the end of this story is going to be? where will you be when it happens
Old Jul 21, 2006 | 09:45 PM
Car: 1992 rs camaro
I got it running earlier today, and no leaks. I only ran it for a few minutes though. Next on the agenda is swapping out crankshaft pulleys and wiring in the fan.
Old Jul 22, 2006 | 12:24 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
You're gonna have to get that easy out removed from that plug. I did the same thing, except the easy out corroded away very quickly, and started leaking really bad when it was hot.
I know its a pain, but its gotta be done man
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
