Camaro went dead for no reason or ???
Old Jul 19, 2006 | 12:00 PM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
My question is this,, I was driving my RS the other day and everything was fine, just another day driving around. It was hot and I had done a long run on the autobahn doing around 100 mph, and had some stop and go in town. I then turn off the car for a quick stop and once I got in to start up again,, NOTHING,, it was like the battery was dead, but everything else worked, light, power windows, radio, I could hear the electric fan kick in while I had the key in but the starter would not move at all. One thing I did notice was that the TEMP gauge was way up there. Any way, I was lucky to be close by a friend who came over to see if I needed to jump it, about a half hour past since she went dead on me,, before we did anything I try to start it again and VIOLA,, it started like nothing ever happen. I drove it home, turn it on and off and still no problem. Weird...
I wondering is there a sensor that would not let her start if it gets too HOT . IF so do you think my Thermostat is on the blink ?? For the record I only drive this car about 3 times a month during the summer and spring, I maybe put 2000 miles a year. But I keep up all the maintanance up to date plus some more.. She's my pride and joy only the best for her. I do have one probability for her not wanting to start up ,, I was looking at other cars at a BMW dealer,, maybe she got jealous,, (not that I would trade her in, just looking to trade my BMW in)
Old Jul 19, 2006 | 12:01 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Starter overheated. Common GM problem. Buy a starter heat shield, it protects it from exhaust manifold heat, which is the cause of your problem
Old Jul 19, 2006 | 12:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
how old is the starter?
Sounds like its on its way out...
As for the heat shield, i think thats a bunch of BS. Especially if your just running manifolds.
My bigazz bosch starter sits less than half an inch away from my headers and its never gave me a problem!
Old Jul 19, 2006 | 12:33 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
welcome to heat soak
Old Jul 19, 2006 | 02:28 PM
Nixon1's Avatar
Just cause it never gave you a problem doesn't make it BS. It's less likely with stock manifolds true, but it still happens.
Old Jul 19, 2006 | 04:28 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Basically the same thing happened to me, except I hadn't driven the car for several hours. I still don't know what the problem was but I think it was a switch of some kind. A way to test is (when the no start condition occurs) if you can jump a wire from the starter positive terminal to the starter solenoid wire with the key on and if it starts then its a switch (not the solenoid switch though). Possible switches are the vats switch or ignition switch. I think there may also be a starter enable switch, but that may be attached to the vats.
Cleotiz
Jan 6, 2018 08:56 PM
TheJoeY88
Dec 31, 2016 07:30 PM
TheExaminer
Aug 19, 2015 10:07 PM
Irocohio
Aug 12, 2015 08:03 AM
Bradsaundry
Aug 12, 2015 12:34 AM
