I'm told a vacuum leak???
Old Jul 19, 2006 | 07:10 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
My car has been stalling and idling all over the place. If I sit at a light the idle goes high to low, hunting. I had the idle air control motor replaced thinking it would solve the problem, nope. Tested TPS throttle body has been cleaned. My mechanic did a vacuum leak down test and told me there is a leak in the number 2 cylinder. I'm told it's not a head gasket, but a intake manifold gasket? Does this sound right????
Old Jul 19, 2006 | 07:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
could be.
get one of those bottles of propane, that plumbers use for soldering. Like $10. turn it on, but don't light it, then with the engine running, and it's doing it's "funny" idle, move it over the #2 cylinder, around the intake. If the idle speeds up, there's your vacuum leak. Move it all around and see where it's coming from.
gta892000
Aug 11, 2019 11:16 AM
bubbaz28
Sep 18, 2015 02:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
