Choke Light ???
Old Jul 20, 2006 | 12:53 PM
InsomniacZ28's Avatar
Car: 1984 Z28
Engine: 305ci V8
Choke Light ???
The choke light in my '84 Z28 tends to stay on.
I dont know if its something stupid like the light being stuck on or if I need to do some sort of adjustment to something as if its a more serious problem.
Can anyone give any feedback on this?
Old Jul 20, 2006 | 12:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How's your alternator?
Old Jul 20, 2006 | 12:56 PM
Car: 1984 Z28
Engine: 305ci V8
I believe its fairly new.
Old Jul 20, 2006 | 01:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
do your power windows work?
every now and then my courtesy circuit goes dead, shut of the car and restart and it's fine. The choke light stays on when this happens as well.
My choke wire also fell off a few times, that'll do it.
Old Jul 20, 2006 | 01:02 PM
Car: 1984 Z28
Engine: 305ci V8
Its interesting that you ask that...my passenger side power window doesnt work.
Where do I find the choke wire?
Old Jul 20, 2006 | 01:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
should be hanging off the passenger side of your carb. There's only one wire on that side, hard to miss. I think it's a green wire.
If it's only one power window it's probably not your courtesy circuit, but you can check your fuses (above your left knee area...)
Old Jul 20, 2006 | 01:35 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
On my '84 the choke light also comes on if there's a blown fuse or other electrical problem.
Old Jul 20, 2006 | 05:31 PM
ede's Avatar
ede
think i'd have the charging system tested
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
