NO SPARK!
Old Jul 26, 2006 | 10:36 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
NO SPARK!
I just replaced my cap and rotor on my distributor and then adjusted the timing. It ran fine yesterday. This morning I try to start the car and all that I hear is the starter trying to get the engine going. It's definitly not a lack of fuel from my carb so it has to be the distributor. Why is this happening? How do I fix this?
Thanks!
Old Jul 26, 2006 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
First thing is to check that the wires on the distributor are still attached, particularly the "Batt" wire.
Old Jul 26, 2006 | 01:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
check to see if your power input on the dist cap fell off or something. Or remove the cap and see if something looks *amiss*.
Old Jul 26, 2006 | 03:29 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Where is the batt wire?
Old Jul 26, 2006 | 03:53 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Old Jul 26, 2006 | 04:01 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
I think he's referring to the Batt wire on the distributor.
Old Jul 26, 2006 | 04:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
is there an echo in here?
Check the drivers side of the distributor cap. There should be 2 plugs going into it, a white and brown IIRC. They plug in from the underside. 2 wires each I think. Both should be there, and in the right place. I think they are keyed such that you can't put them in the wrong spot (brown one in whites spot, and reverse.) One of the plugs (brown?) has a thick pink wire in it, that'd be the batt wire IIRC.
Old Jul 26, 2006 | 05:00 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Old Jul 26, 2006 | 05:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
seriously, something wrong with your computer there or what?
pic
The arrow "kinda" points to a pink wire, that's the batt wire. I was actually pointing to the oil pressure gauge, but close enuff.
Old Jul 26, 2006 | 07:20 PM
JB22's Avatar
I had an issue after putting new cap and rotor where I got a little oil or something on the rotor, so I got 0 spark. Only reason I knew I had something going on was because I had spark, then I didnt have spark after I pulled it off.
Clean up the contacts on the cap and the rotor to make sure u didnt get something on there.
Old Jul 26, 2006 | 08:50 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Thanks. Yeah sorry about the duplicate messages, my browser must of been set on constant reload.
Old Jul 26, 2006 | 09:11 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Yeah the batt wire is in and the connections are clean. So now I'm really stumped.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
