can you tell me whats missing?
Old Jul 27, 2006 | 06:14 AM
xklipze's Avatar
To the left of the (front of the throttle body) i found 2 random plugs, and the came like this, and ran great..
Now i kinda want to know what these 2 plugs goto, whats missing lol??
you can click the picture to make it bigger
The engine is a L98 inside of a 1991 Z28 and everything is factory except this missing piece.
350 TPI
Old Jul 27, 2006 | 10:07 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
IIRC those were AC connectors, you still have working AC?
Old Jul 27, 2006 | 10:48 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
looks like someone removed your AIR system
Old Jul 27, 2006 | 02:32 PM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
Are they 2 tubes? Those are for your coolant lines.
Old Jul 27, 2006 | 04:52 PM
xklipze's Avatar
i got a better picture
u can click to enlarge.,....
my a/c doesnt work...
with these two plugs not connected to my car, it didnt stop it from running badass before
i also found a random plug not going to anything.. it was a red wire.. but all these things didnt prevent the car from running great before.. but figured now is time to investigate..
the random plug/wire is located on the right side near the firwall on top..... of a bunch of random stuff,,,,
Old Jul 27, 2006 | 04:59 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I've got those two plugs chillin in the same spot from when I removed AIR
Old Jul 27, 2006 | 05:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yup. Somebody removed your smog equipment. Err most of it anyway. I dont know if your smog pump is still in tact or not.
Red wire is probebly the fuel pump service turn on wire.
Old Jul 27, 2006 | 07:18 PM
Car: '72 Chevy Nova
Transmission: TH350
yeah thats the AIR, my bad.
Old Jul 27, 2006 | 11:45 PM
xklipze's Avatar
#1 so its obviously smog/air related.. is this taking away from horepower? its good to go i assume , and you guys seem to not think its a problem, thanx alot..
#2 The red wire/ plug is bundled with the orange wire going to the Engine compartment LAMP.... i assume this had something to do with the air/smog removal..
open/closed case thanx guys
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
