engine cast # question
Car: 87 IROC-Z
Engine: POS 305
Transmission: 700-R4
Axle/Gears: DUNN0 STOCK DISK BREAK 10 BOLT
ok i know i got skrewed but i will live on to see anouther day
i was told my 87 iroc was a tpi that blew up and was switched with a 4 bolt mail 350 but i didnt check the numbers because the car was running when i went to get it and didnt want to stick my hand back there when it was hot
so any ways i took his word for it and got the car
well i got the car home and let it cool off and checked the numbers it is a 86 305 i was wondering if it could be the origional block for the car it is a 87 iroc z28 but would it have a 86 engine in it or a 87 ?
nick
nick
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
engines and parts were cast a few months before the bulding of the car, so its possible that the casting of the engine is 86 sure, if the car is an early 87 especially
is it a centerbolt head engine or ?
give us numbers off front flat stamping pad of the block under the alternator, and also the casting code off back of block if possible
the front stamping code will do it though
search on google for this:
nastyz28.com suffix codes
Car: 87 IROC-Z
Engine: POS 305
sorry bout the caps lock i keep hittin the button today lol
is it true that the tbi engines were all roller motors?
the heads and the intake were changed i think it had the four valve cover bolts around the outside and a edelbrock performer rpm intake (highrise alum.) and a 750 meh. secondarys carb i was told
nick
Car: 87 IROC-Z
Engine: POS 305
um
here is a crappy pic
? maybe not it wont let me upload
back number is 10046164 i for got i hade it wrote down here
Engine: 4.3L Z TBI
305 in 1986
what heads are on it ? 86 older or 87-95 ?
i bet the engine is not original to the car
another way to know real quick is there should be the last 7 digits of the vin code stamped on the front pad of the engine under the alternator, it should match up with the last digits of the car's vin code
if its original
good luck
if its original
good luck
Car: 87 IROC-Z
Engine: POS 305
um
the vin # is 1G1FP21F8HL108101
THE STAMP ON THE FRONT OF THE BLOCK IS K1187560
I WILL BE PULLING THE VALVE COVERS OFF THIS WEEKEND TIO REPLACE THE GASKETS AND WILL GET THOSE NUMBERS THEN
NICK
NICK
Transmission: 4L80E/4L80E
The '86 block is unique because it had flat tappet lifters like the earlier years but was the first year for the one-piece rear main seal that carried on in later years.
It is possible to have a leftover '86 block in an '87 model chassis, but the different VIN #'s is a pretty clear indication the engine was swapped out and the older one put in.
Car: 87 IROC-Z
Engine: POS 305
humm
i cant figure out this code from the front of the block lol
eather way any one wanna buy it?
lol
it runs pritty good
nick
lol
it runs pritty good
nick
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
nick
nick
In f-bodies yes, for trucks no. However, all TBI blocks should have roller provisions cast into them (A few bosses that need to be tapped).
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
