cursed valvetrain...
Old Aug 4, 2006 | 11:19 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
This engine only has 6K on it...
on #8 intake and exhaust rockers and intake rocker on #6 the nuts keep backing off... i know i could put nylocks on there but i'm just curious if this is a common problem with MrGasket screw in studs or not... the rockers are Comp Magnum 1.52's cam is right around 500 lift...
Old Aug 4, 2006 | 12:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't think nylon will hold up to the heat. Have you tried new stock rocker nuts?
Old Aug 4, 2006 | 01:25 PM
Add a jam nut to them. Just a regular hardware-store or parts-store nut works fine.
Old Aug 4, 2006 | 01:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
mrg collared or non collared ones?
Old Aug 5, 2006 | 07:36 PM
Engine: 450HP 355
Transmission: TH350
i've just got the ones that came with the rockers for now... so adding a 2nd nut to lock it in is ok?
I allready tried loctite and they backed off in just a couple minutes... I also tried some other automotive glue stuff i had, i haven't driven it enough to test tho...
FormulasOnly
Sep 6, 2015 10:42 AM
Synapsis
South West Region
16
May 13, 2004 07:25 PM
fatass
May 5, 2004 11:13 PM
dimented24x7
Mar 10, 2004 04:54 PM
thunder87
Jul 31, 2002 04:28 PM
